Need advice on speakers, sub and amp..
Post all your Nissan electronics, car audio and stereo questions here!
sr20-thoj
Car: 89 nissan 240sx coupe
I have a 91 240sx coupe.. when I bought it came with some 4x6 pioneers in the fronts.. and stocks in the rears.. Im looking some in the rear maby something new in the fronts also.. was looking through the forums and cant find a solid answer on what size they really are.. so are they 6.5?? Also looking for sub and amp.. something not too loud but enough for a good kick.. what do you guys recommend.. looking to spend around.. maby $200-250 only..
coolhand
Car: 1995 Nissan Maxima SE
sr20-thoj wrote:I have a 91 240sx coupe.. when I bought it came with some 4x6 pioneers in the fronts.. and stocks in the rears.. Im looking some in the rear maby something new in the fronts also.. was looking through the forums and cant find a solid answer on what size they really are.. so are they 6.5?? Also looking for sub and amp.. something not too loud but enough for a good kick.. what do you guys recommend.. looking to spend around.. maby $200-250 only..
You may not find much for that amount new, so hit ebay for some used components. To be honest, I would spend some time checking out other peoples systems and see what components they have and how they sound before you drop a lot of money on you system.Sub components I would recommend for your budget:
Sony Xplode mono amp for the subs10 or a 12 Kicker Comp VR's sub 4ohm DVC (to get more power from the amp) in a ported box.
Kenwood component speaker set.
If you budget is tight you may have to buy pieces when you have money.
Good Luck
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
So you're wanting replacement speakers in the rear, a sub, enclosure, amp and wiring all for 200-250? Ouch. It can be done, but you'd be better off buying one peice at a time.
PoorManQ45
I'm going to recommend a set of DLS RS6 up front. I personally would put a set in the rear also.
Then get a four channel amp to power all this. Call it a day until you save up atleast $200 for the sub and amp alone.
ncs14
Car: 1995 240x se
you could get some cheap stuff on ebay that will fry in a day for 200-250!
