Need advice on replacement struts for my 1997 q45
q45newguy
Car: 1997 q45
So I really do not want to spend a lot of money on this car. But I would like to do the front struts (left front rattles when pot hole or bumps) It is not the touring q45. There is also a small leak on the front rack and pinion (that's what mechanic said)
Any advice on cheap replacements? Thanks
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
q45newguy wrote:So I really do not want to spend a lot of money on this car.
That first sentence sounds like you got the car off of Craigslist really cheap (and that's fine). But this is a ~$50 car when new so it should always be treated as such.
q45newguy wrote:But I would like to do the front struts (left front rattles when pot hole or bumps) It is not the touring q45.
Try calling Infiniti Of Scottsdale: 1-888-344-6346
q45newguy wrote:There is also a small leak on the front rack and pinion (that's what mechanic said)
Thanks
Do you know exactly where the leak is Because it maybe as simple as a loose clamp. Just make sure the power steering fluid is always full.
Welcome to NICO.
