Need advice on new parts I/H/E
driftin240
Car: in love with cars
I have a 95 s14 and im about to put on headers intake and exhaust and I am wondering what the best type of parts would be for horsepower gains. Also I was curious if there was a cold air intake on the market for the 95-96 240 other than the Injen cold air extension. I've heard good things about Hotshot headers and I was thinking about Apex-i N1 duals...any thoughts thanks
driftin240
has anyone seen the bomex eye mask that is made for the the s14 if so tell me your opinion because i was thinking of getting it soon
http://www.bomexaero.com/images1/s14/ad138.jpg
Structure240sx
you made good choices with those parts. i have them jsut iwth different exhuast but i will be switching to the n1. i have the full bomex kit u can check out the site in my sig. the eye mask woould be fine to get but i dont suggest gettin a whole kit if u paln on it too much money with no performance value. loks great but ehn u have to always be careful
Cyberkreig
Car: 1993 Nissan 240SX SR
I love the look of the N1 Dual, but remember it was designed for a turbo.
driftin240
that eye mask looks good on your 240 and that bomex kit is just badass
driftin240
did you install that yourself if so how bad was the install I was thinking of doing it at a friends garage
Structure240sx
the install is pretty easy. the header took a couple hours. the pain in the *** was the rusted bolts to the dummy cat just use pb blaster on those and the egr fitting and let it soak in then u wont have a problem.
driftin240
i meant the eye mask does it fit on fairly easy or should i get it done professionally
Structure240sx
i had the entire kit done professionally but looking at it now could have done it myself. but just the eye mask is a snap. its 4 clamps that hold it to the hood jsut have to get it painted then 5 mintues later ur good to go
daniel240
Car: cars/motocross
the only header you should get for the 240 is hotshot. they are by far the best header you can get. as far as intakes, injen is very good, i personally have a hotshot intake and i like it a lot. there are a lot of different options you could go with for exhausts.
driftin240
i want to get a cold air intake though and i think the hotshot is only the ram air...Injen is the only CAI ive found
daniel240
Car: cars/motocross
yea i think injen is the only company that makes the extension that goes down to the lower bumper.
creophus
Car: 240SX SE & 200SX
How much power does the average cat-back add to the stock engine?
Structure240sx
maybe 5 hp if that on a stock engine
MarkEmark
Car: fully-built '95 240sx KA-T
Headers-go hotshot. They're a pain in the *** to install, good luck getting the EGR tube loose, mine was a 95 and I was about 2 seconds away from hacking it off when it finally budged (after a fulll can of PB blaster, a propane torch, and a plumbing wrench w/torque extension.)Exhaust--I don't suggest N1 duals unless you're going turbo. The large diameter tubing may sound bad-a$$, but you'll loose exhaust gas-velocity with the large piping--you don't need that big of exhaust piping for a NA 2.4 liter four cylinder, unless you're going to go turbo in the future. Plus, you'll loose torque with the bigger pipes. I suggest the same exhaust system I have on mine, that I'm EXTREMELY pleased with. It's a Tanabe Super Medallion hyper-spec exhaust, 60mm, stainless steel T-304 piping the whole way back (top quality stainless steel, about 2.25" exhaust piping.) The exhaust system is excellently constructed, fits perfect, sounds awesome, gave me decent power gains, and is quite from idle to around 3k, it really picks up after that, especially if you have headers and a CAI.Intake-Don't go with anything unless its CAI, it just doesn't make sense to have a short ram air intake sucking in wicked hot air. Make your own if you want to, I made mine out of 3" mandrel bent piping that I got from JCWhitney--gave me a good amount of power, is completely custom, and looks awesome.-Marc
driftin240
As of now I'm not turbo but I'm thinkin about either goin SR20 or gettin a turbo kit for graduation, and while im on the subject what would yall recommend i have 65k miles on my engine and by the time i go turbo probably like 70-75k should i go SR20 or what?
Structure240sx
turbo the ka i would but i have 120,000mi and wont have the money for a fuliy built engine real soon. if u are definitly goin turbo which u should jsut get exhuast the other stuff u wont be able to use.
daniel240
Car: cars/motocross
What! Mine were so easy to put on. i had no problems at all, everything came off easy and everything lined up perfectly.
NewYork240
Car: driving and learning about imports
I'm thinking about getting a hot shot , but i've heard that they suck as far as installation goes. I've also heard that they fixed the problems after 2001 and the new ones are perfect... i'm not sure what to think
Structure240sx
i got my egr tube off after about 10 minutes and alot of PB. the newest generation i have is great. perfect fit and no check engine light or anything great improvement in power
