C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Jun 14, 2005 10:07 pm
I used two different specs of T04B's. They will work fine. Not the most flexible or ideal turbo, but it gets the job done well. While it won't have the responsiveness of a T3 turbine, lag/boost threshold will probably not be that big an issue. It's doubtful the turbine that you would find typically mated to a T04B will be on the larger side of the t4 Turbine family. But the compressor and turbine trim is important to know in order to get a better picture of how this turbo will perform.
