574-240sx wrote:I have done a few manual swap. on a OBDII S14 you may get a check engine code for a sensor but everything will work fine. You still can retain you stock ecu. There are no cold start problems, if anything it will idle up a little higher briefly, if you tap the gas.
^^yea... what he said^^
You may also find these directions very usefull. They should answer most, if not all of your questions. http://www.ka24development.com....htmlhttp://www.ka24development.com....html
If your doing the swap on your own, a factory fsm can come in very handy, especially when taking out the auto and putting in the manual. You can find them for free online, I think there is a link up in the general forum. Best of luck.
