yes, i recently finished my doors. check the link again, theres an update w/ new pics on the bottom of page 1.allensteiner wrote:hey G4. so did you do your door switches? i went to radioshack but they couldn't "guess" which led's i need even though i brought one in and i couldn't find anything on them in the fsm. btw...looked like your clock was blue from the other forum. is it or just looks like that in the pic?
$6 a piece for the climate bulbs is nuts. are you referring to the mini incandescent bulbs or the square green looking LEDs? for the leds, def swap those out w/ better ones. i used 3mm blues.allensteiner wrote:i got the 5mm led's off ebay - hope they fit but if not it's only $5 wasted. i got 194's in the doors and gauges. wanted to do my ac buttons with oem bulbs - mine were all dead - but they're over $6 a piece!!! so i'll wire led's in. for the clock and ac displays i went with 2 layers each of red celophane from a arts&cratfs store - $4 a roll is a lot cheaper than have an electronics shop switch out lcd filters. i should get back from work before 5am so i'll post pics.
aside, don't know what happened but my driver door light stopped working, so sometime i'll have to pull the panel off to see if i have a loose connection somewhere. s***'s starting to look sweet. next project will be fixing the tears in front seats - leather. i'm thinking 2 tone - add burgundy to match the lighting and body color
