OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Wed Jun 02, 2010 4:57 am
Yeah needs a heater core and a transmission rebuild or replacement (because once your in there you will find shift pad wear, bearing wear, yada yada yada). Probably cheaper to replace it, then while your in there you should do the rear main seal, and complete clutch kit. So if your handy and can do it yourself your looking anywhere from 700-1100 to fix..... but then after all that your got a car that you fixed that someone else probably beat on. Plus he rates the body a 6 of 10..... I think you can do better, save up another grand and get something much nicer.
