SXFreak »
https://forums.nicoclub.com/sxfreak-u41857.html
Sat Jun 10, 2006 9:34 pm
I have swapped a 92 KA24DE (had an auto trans) into my 90 that ofcourse HAD a KA24E. I converted the KA24DE to the manual trans that was already in the 90, by swapping flywheels. I also swapped the ECU and harness from the 92 into the 90 to match the engine.My problem is, I can't find the connector plug for the neutral safety switch. I have the wire coming from the trans, but can't find where to plug it in. I can't even find it on the OLD Harness!! Poof, disappeared!! lol.I wonder if it would work anyway as the ECU is for an auto trans.I would like to just bypass it. I know this will result in starting in gear, but I will be the only one driving.....I know the neutral switch pin location on the ECU is #34, but what do I do to fool the ECU into "thinking" it's ok to allow the starter to engage?Is ther another way? Remember, the wire from the manual trans is not/cannot be connected..... Do I merely run a jumper from #34 to chassis ground? What?....PLEASE HELP????? It's driving me NUTTS!!! :-0
