AllTurBo »
https://forums.nicoclub.com/allturbo-u2336.html
Thu May 22, 2003 10:24 am
You don't need fuses, I guess they are just for safety sake. if you fuse all your individual electronics you should be fine. I guess the benefit of having a fuse on the battery line is that if the positive cable get pinched, frayed, or comes in contact with a ground that fuse will blow instead of your other fuses. The safest thing to do would be to find out the ampere rating on the alternator and get a fuse that matches that.
I had my battery in my trunk when I had my KA. the car didn't really run the same and it puts more stress on the alternator. IMO it's better to just get a smaller battery. Unless you want to Auto-X and it's required for your class. Some classes require a trunk battery with a kill switch.
