Landlockt »
https://forums.nicoclub.com/landlockt-u180341.html
Sun Mar 06, 2011 1:17 pm
I just picked up an '89 4 cyl. 4x4 ext. cab. that needs a lot of work:
It has a lot of little things that need to be taken care of, e.g. right rear taillight lens, non-functioning heater/fan, driver's side door panel needs to be replaced, the drivers side motor mount weld has snapped, exhaust pipe from muffler back, etc.
How do I find out what other years have parts that are compatible?
Below are the major problems I need the most help with in order of importance (as I see it).
1) The front end is a mess, I need to hold the wheel at 9 o'clock to go straight and if I let go of the wheel it quickly goes to 3 o'clock and pulls HARD to the right.
2) The leaf springs are flat and one leaf on the passenger side is snapped in half.
3) The clutch will need replacing sooner rather than later. Someone suggested an Exedy. I can pick one up of of eBay for $100 delivered.
Any help/advice is appreciated. I also need some tips on good parts suppliers.
Thanks
p.s. this truck has 255k on it
