Need Advice... going to the Stealership!
ducz24
Car: 02 Altima
Well im going to the the stealership this friday for my transmission/synchro wine... i had this for a couple of weeks now... its just bothers me... its a whine from 3rd gear on 1.5-2.5k RPM at about 30MPH and into 4th at low rpms and crusin at around 60-70 on 5th.... its a whine that sounds like this....
3rd gear low rpm/speed and by the end shifting to 4th at low rpm/speedcruisin
anyway im going to have them check it out.. i hope it has something to do with my transmission coz thats under warranty..
now my question is I have mods in my car that i guess theyll see such as Intake, FSTB, Block off plate, NWP spacers (i dont think theyll notice this), y-pipe and my resonator/crimp removed... would they b**** about these mods? The only thing i can take off is the FSTB, Block off plate, and y-pipe.. should I? or dont even bother? What are your experiences with the stealership and seeing your mods?
Thanks in advance.. my car is 06 Altima MT w/ 43k miles
ps - i just recently found out (1st time trying last weekend) that topping off 3rd @ 100~110 and going to 4th, well it lets say its in gear but wont catch... any ideas? and yes i tried it a couple of times and made sure its in gear but wont catch..TOB maybe?? IDK...
Modified by ducz24 at 6:51 AM 8/5/2009
marlin29311
Car: 2008 Infiniti G35x
Are you going to have warranty work performed? If not, and you're just going to Nissan to have them look at your Nissan, they shouldn't give you a quarrel, since you're going to be paying. Many people have problems when it's in-warranty work that's being done...
ducz24
Car: 02 Altima
well im going there for them to check it out... now if it has something to do with my transmission then that should be under warranty.. i hope
erick.s
Car: 2008 Altima 3.5SE Coupe
My guess is that they'll give you a hard time. A dealership can definitely make a case that the mods you've done have overstressed the transmission, therefore no coverage. I'd remove all that you can and keep your fingers crossed.
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
erick.s wrote:My guess is that they'll give you a hard time. A dealership can definitely make a case that the mods you've done have overstressed the transmission, therefore no coverage. I'd remove all that you can and keep your fingers crossed.
especially y pipe and intake bc thatll be something theyll b**** about
