Need advice for 2006 Infiniti m35x wheels !
M35xInfiniti06
Car: 2006 Infiniti m35x
Will 20x10 wheels with 275/30/20 tires fit well with a 1.5 in drop on a 2006 Infiniti m35x ( AWD ) ?!?!
Ilya
I think there is a wheels thread somewhere around this forum...with a bunch of shared specs, sizes and pictures. You should look for it.
Amgberg
Car: 2006 m45 sport blue tint, STR 20x10.5, full Megan exhaust.
2010 E63 ////AMG stock
20x10.5 all the way around +35 offset like mine will give u this look. Image
airmanhoward
Car: 12 M37-Current
08 civic lx sold
06 M35x Totaled
2000 S10 sold
Ford contour svt-sold
91 caprice-sold
90 & 93 maxima-sold
96 ford escort-sold
She's beautiful
Amgberg wrote:20x10.5 all the way around +35 offset like mine will give u this look. Image
[/b]
KC611574
Car: 2009 Nissan Maxima S
I also have an '07 M35X and was thinking of getting a set of Rohana forged wheels 20x9" 25mm offset. Do you think they will stick out past the fenders? My car is currently at stock height...for now.
szh
Car: 2018 Tesla Model 3.
For an X model, my only advice (separate from the fit which others can comment on) would be to make darn sure that all four wheels are identical and all tires are the same brand/model.
I.e., no staggered setups.
This is required to minimize/reduce wear and tear on the all-wheel-drive Nissan Attesa system.
Amgberg
KC611574 wrote:I also have an '07 M35X and was thinking of getting a set of Rohana forged wheels 20x9" 25mm offset. Do you think they will stick out past the fenders? My car is currently at stock height...for now.
20x9 +25 will be flush and +25 can clear BBK use 245/30 if u want a tad round side wall stretch or 255/30 for square side wall
Amgberg
szh wrote:For an X model, my only advice (separate from the fit which others can comment on) would be to make darn sure that all four wheels are identical and all tires are the same brand/model.
20x10 square 245/35 you will be fine
Amgberg
airmanhoward wrote:She's beautiful
Thanks
KC611574
Thanks for all the info. My only other concern was since my car is sitting at stock height would that cause the wheels to stick out? I know that lowering the car will cause the wheels to tuck but I'm not sure how they'll look I the car until I get the car lowered.
Any suggestions on lowering the car, I'm not looking for anything too extreme, just want the car to sit 2-3" above the wheels.
Amgberg
KC611574 wrote:Thanks for all the info. My only other concern was since my car is sitting at stock height would that cause the wheels to stick out? I know that lowering the car will cause the wheels to tuck but I'm not sure how they'll look I the car until I get the car lowered.
Don't worry about it. I road around for months on stock hight with 20x10.5 +35 square till I went to H-tech now to BCs. And you can drop the car 1.5 front and 1 inch in the rear will sit perfect. Are cars the front fender is cut definitely from the rear so to get a even drop u have to lower the front .5 inches lower that the rear. If u go even the rear will sit lower and u will have a sag look.
Amgberg
How my car sits now for winter from the previous picture. And correction always set it 1/4 lower in the front than the rear to even the drop with these cars. I see so many M35/45 lowerd and the rear is lower than the front because they didn't take into account the fender is cut higher than the rear from factory and when you put are cars in drive in park the rear dips so I take all that into account when I tune my ride hight for a clean daily driven stance. So now when I drive, when looking at my car from the out side my stance is perfect while in motion. So 1/4 in always lower in the front no matter the hight Image
KC611574
Thanks for all the help Amgberg. I see that you have an M45 Sport, the only reason I'm concerned about the fitment is that the M35x sits higher than the other models. And I've also heard that the AWD model can't fit too aggressive of an offset due to the AWD system. I was hoping someone with the x model could confirm this.
Amgberg
KC611574 wrote:Thanks for all the help Amgberg. I see that you have an M45 Sport, the only reason I'm concerned about the fitment is that the M35x sits higher than the other models. And I've also heard that the AWD model can't fit too aggressive of an offset due to the AWD system. I was hoping someone with the x model could confirm this.
Who ever told you that is wrong. Are cars rear wheel or all wheel can run the same variations of wheel spec/tires. 20x9+25 20x10.5+45/+35 20x10+45 square 20x10.5 +35 square trust me. This is a nicco member name Hatsuharu it's a X with 20x10 +45 255/35 square Image
KC611574
Thanks for ask the help Amgberg!!. Note I just need to find someone to Photoshop the wheels I want on my car.... Lol
prince1017
Car: 2007 infiniti m35
Amgberg wrote:
Wed Jan 18, 2017 11:44 am
lovely car Bro, im from the caribbean and im really looking for an aggressive look ... did you have to fabricate anything? roll fenders, spacers camber? because some people are telling me 20x10.5 +35 is tomuch for the front of the m35 .
im thinking of going 20x10.5 +35 all around
please help, thanks
