Need Advice about Injectors/Boost
jdmae86
Car: S14 - RB25DET SII
Modified by jdmae86 at 1:15 PM 6/2/2008
lilskyline240
Car: 90 240sx w/ rb30det
to me it seems like you just wrote out a parts list of stuff you want to do to your car. Get the motor in the car and running perfect before you think about doing any modding. It will save a ton of headaches in the future. Judging from the fact that you dont know what size injector to run with this setup im guessing you havent done to many modifications to motors. RB's are EXPENSIVE just to let you know. But done right, they will take all the abuse you throw at em
jdmae86
lilskyline240 wrote:to me it seems like you just wrote out a parts list of stuff you want to do to your car. Get the motor in the car and running perfect before you think about doing any modding. It will save a ton of headaches in the future. Judging from the fact that you dont know what size injector to run with this setup im guessing you havent done to many modifications to motors. RB's are EXPENSIVE just to let you know. But done right, they will take all the abuse you throw at em
umm i already own all these parts... they came with the motor... the motor was running fine in his car but he was running an afc and low boost. So i picked up the emanage and wideband.... I just wondering if 550's would be good for this setup running prob 14lbs
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Plenty of injector there. You're good to go.
Carl H
emanage + nissan ecu + large injectors = fail.550's are good for about 400whp before they get over the 80% duty limit.
jdmae86
your right... but i wanna c how far it gets me & my goal right now is only 350whp but i want there to be a little head room for later...
Carl H
well the question is how fast do you want a melted piston...do it right, do it once.
KlanjacOFF
Car: Nissan 240SX
Forget about injectors, just run meth
jdmae86
Carl H wrote:well the question is how fast do you want a melted piston...do it right, do it once.
What are you suggestions then for fuel management...
s13point5
Car: 89 240sx
why did you edit your first post and take out your parts list?......
