Need advice 1995 240sx will not crank
sebastianpiz
Car: 240SX
Hi,I have a 5 speed 240sx. Car will not crank. I have tested the Battery which is o.k. I removed the starter and have Kragen tested it and it cranks fine. What else could i check on the car. trying to avoid to drive it to a local shop for $$$ expensive repair. Car runs if i push start it.
Thanks,
jmorgan6
Car: 1995 240SX 5spd
Does it even turn over? or just click, or do nothing?
If it doesn't turn over, or even click.. turn your lights on and do it.. does your lights dimm?
scottydog
Car: 1992 240sx
If the car push starts, the starter checks out, and the battery is good then the starter isn't getting electricity somehow. Perhaps ignition switch or bad connections to the starter?
