Need ACL bearings for rb26
PurpleGodzilla
Trying to find the source for ACL bearings for my rb26..What kind of bearings are you using for your rb26..I have good luck with ACL in my honda and would like to continue using them in my nissan.
EmaSe
Car: 240sx convertible
go to http://www.greenline.jp they have nismo main bearing set and rod bearing sets and they also have the tomei bearings too for the rods. i think i order mine from them.
fito
it would be nice to get a contact to get ACL because of there price. Those bearings are super cheap compared to nismo or any other
BoostFab
Car: S13cp, S13fb, S14z
there site is: http://www.acl.com.au maybe someone can try to contact them for a dealer near by.
fito
I tried like 4 times to contact them with no luck!
PurpleGodzilla
if i can get the exact part numbers for the standard size bearings. I can contact my acl bearings distributor here...I have access to 2 of them. However they need to have the part numbers since they don't usually deal nissan so therefore not familiar with the rb series.
I tried looking on their website at the catalog. They only thing I can figure out is that the rb25 and rb26 shared the same part number for the main bearings. As for the conrod part number, I can't find it ...There is a number but I am not sure if that is the part number (f780)
gawdzilla
Car: none
i can get you these... send me an AOL instant message at blops714.
DETurbine
Car: Nissan S13 RB25
Keep us updated if possible. I am in the process of rebuilding mine and will need some bearings for my RB25 here pretty soon.
gawdzilla
Car: none
sorry about the confusion. i meant i can get the part numbers for the OEM bearings, not the ACL
DETurbine
Here is what I have found out so far by doing some research for the RB25 and 26.
For the ACL main bearings you are going to have to use the RB30E main bearings. The ACL catalgue has the RB25DET mains listed, but they screwed up on it, they only have the RB30E's, which work for both the RB25 and RB26.
For the Conrod (a.k.a. Rod bearings) all the RB25, RB26, and SR bearing are all identical. They actually sell a set of 6 of them now so you do not have to buy two sets any more.
I called ACL direct and they gave me a ruff estimate, since they do not sell these direct unless you have an account with them. He said it will be about $135 ($100 for mains and $35 for conrods)
Modified by DETurbine at 9:59 AM 2/8/2005
PurpleGodzilla
Sorry for not updating. But here are the info. I found so far. And yes, you are correct about the interchangeable.
Here are the parts number (main bearings)1. 7m2394 (they have in standard or oversizes)2. 7m2394H (race series)3. 7m2394HX (race with .001 extra oil clearance)
Rod bearings are 6b2960 (or you can buy 2 sets of 4b2960 and split it up ).
BoostFab
thanks for the updates guys....now we need to find out who is their dealer here in the states side.
BoostFab
i spoke with Lightning Motorsports earlier after seeing their site carry ACL bearings....they will get back with me to see if they can get ACL bearing for Nissan motors.
PurpleGodzilla
the number to acl u.s. distributors is 1-800-847-5521. Talk to chris.
BoostFab
did you order yours yet?
DETurbine
I have called ACL and Chris told me that you need to be set up with them in order to get parts.
gawdzilla
Car: none
how do the ACL bearings work in terms of sizing? only 2 sizes (regular and oversize)?. Does that mean you have to grind the crank down to fit the bearing regardless of the OEM sizing? In that case I guess you would buy the bearings and make the crank fit. (which might cost more)
OEM sizing gives you 7 different sizes for mains, and 3 sizes for con rods. If going OEM bearings, it is the other way around- you buy the bearings to fit the crank. (i think this method is cheaper because you dont need to cut the crank to spec. just measure it and most likely an oem bearing will fit.) other than that, all you need to do is micropolish and balance...
just something to think about before jumping on ACLs. I know Power Enterprise makes bearings too (all OEM sizes aavailable..)
BoostFab
gawdzilla wrote:just something to think about before jumping on ACLs. I know Power Enterprise makes bearings too (all OEM sizes aavailable..)
i know they make bearings for the rb, i can't justify $50-$60 each piece. even with polishing the crank to fit the ACL bearings, it end to be extremely less. and , nissan bearings suck balls....
gawdzilla
Car: none
i hope thats not totally true... i got oem nissan bearings damnit
PurpleGodzilla
DETurbine wrote:I have called ACL and Chris told me that you need to be set up with them in order to get parts.
The main bearings (they had only 5 in stock for the race series) parts number shows up on their computer but at local dealer they will not show up. I went through couple of phone tags and finally I got fed up and called back to Chris and explain the situation. He then asked his supervisor to ok and will C.O.D. them to me without an account. I ordered 2 sets of main and 3 sets of rod because me and a friend are building 2 engines.
Tell him Trinh sent you. Explain to him the situation that you are building an engine that is not normally exported to the U.S. and that no ACL dealers will stock them. Be nice and he will try to work with you.
PurpleGodzilla
gawdzilla wrote:OEM sizing gives you 7 different sizes for mains, and 3 sizes for con rods. If going OEM bearings, it is the other way around- you buy the bearings to fit the crank. (i think this method is cheaper because you dont need to cut the crank to spec. just measure it and most likely an oem bearing will fit.) other than that, all you need to do is micropolish and balance...
You have to take in consideration of 50K plus miles of wearing on the crank itself. Not to mention rebalancing and micropolishing the crankand, line honing the main tunnel. But to properly blueprint the bottom end, you will have to measure the inside journals of both the main caps and rods, the crank and subtract those numbers. The differences in the readings in references to the ACL bearings tolerances will give you the proper sizes. Even then, I still plastiguage every engine I have built.
For the past 10 engines from Honda that I have built plus many others that I have helped building (most of these engines are 500whp plus) The standard falls within specs. Honda uses the same number system like nissan.
I really am not advocating ACL as the superiority bearings over OEM or other japanese bearings but mainly just that I have been using them for 3 yrs now and would like to continue using them.
Skyline australia and skyline downunder users use ACL a lot but of course thats because they are an australian company.
BoostFab
PurpleGodzilla wrote:He then asked his supervisor to ok and will C.O.D. them to me without an account. I ordered 2 sets of main and 3 sets of rod because me and a friend are building 2 engines.
do you think you could get chris to send you another set, for me?
