stewartmotorsport »
https://forums.nicoclub.com/stewartmotorsport-u162544.html
Fri Aug 12, 2011 5:02 pm
That is correct - you do not need a cert for R134 - although they still get pissy if you vent it into the atmosphere.
Although it turned out that he was indeed low on refrigerant, compressors will also not kick on if the pressure is too high. This usually indicates that the system is plugged up somewhere. Often times, the compressor will "vent" excess pressure as a fail safe. Scared the stink right out of me first time I heard that.
When that happens, you have to open the system, find the source of the clog (orifice tube, etc), remove the tube, put that section of pipe back together, flush the whole system with a cleaner, follow that with shop air - LOTS OF air - replace the orifice tube (or whatever your car uses) with a new one, replace the drier, replace the compressor, evacuate the system, inject oil, start car, and start filling with refrigerant.
Ask me how come I know so much about A/C all of a sudden? lol
