loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Sep 03, 2010 12:37 am
How did you know you have to replace the pump-actuator? It seems too early for that component to fail. Most of the problems with ABS/VDC are associated with relays and wheel sensors. But of course, pump-actuator failure is a possibility.
And yes, finding a 6th Gen Maxima in a junkyard would be difficult.
