need abit of advice...
180sx
sO HERE is my setup : 89 ka24e 200k kms on it. steady comp 160150150165 putting in new gasket set timing kit head studs.now i have fmic with 2.5 inch piping i got a rebuild turbo tdo4 thats mitsu t25 used on every talon,etc i figue if mitsu 2.0dohc can do well over 250hp with some fine tunning and sr20 do well over 250hp with t25 thats also 2.0 dohc . So i 2.4l sohc should have nice long turbo curve doing over 200hp with no lag but rather some lack of power towards the red line.now people on ka-t are telling me that i will fry tubo to shiets before i hit over 200hp , now it doesn't make sense to me ...why would i not be able to do what sr20 and dsm do with the same turbo but .4 bigger engine.?? also stock wastegate is set at 10psi, now how high can i boost this thinggyconsidering its t25 ??? 20psi hehe i am hunting for e-manage and rx7 inj right now. i have aslo hacked up my factory mani and weldded it up with stock bottom mount dsm mani.
superDorifto
Car: 1997 Eclipse Spyder - AWD/5spd swap in progress
1995 Q45 - 5spd swap in progress
1984 200sx hatch(KA-t swap) - 355WHP
1991/1993/1995/1997 240s - Dead
1982 200sx hatch - fixed/scrapped
im a former dsm'er, the T25 is a big piece of crap. its nearly maxed out at 200 hp on a stock 2nd gen eclipse. at 250, its pumping nothing but hot air. its set at ten psi, but pushing it much higher isnt a really good idea. Those turbos are ment to stay in the 150-250 range, period. It doesnt matter that the KA is .4 liters bigger, the T25 will still suck.....
Mustangs_Suck
I'm pushing 7psi on my T25 and have hit 200rwhp 205rwtq. the engine comp is a bit low, so i'm sure if it was more healthier and running cooler (it got a bit hot on the dyno run) it'd be even more powerful.
I don't know what it's limits are, but I do know they aren't anything too special...they are good for a starter/budget set-up, while my car isn't **** your pants fast, it is very fun to drive.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
The largest T3 maxes out around 5000RPM on a KA, so imagine a T25.
you said "no lag" yah no kidding, you will be burning rubber trying to get out of a parking stall...
and those compression numbers don't look too hot, you have a 15psi difference between cylinders, my advice, swap a DE in there
Modified by Checkered-Member at 10:03 PM 6/16/2005
