Need AAC valve assembly
Doogz
Car: '89 240sx coupe
I need the entire AAC valve assembly as mine is broken. I was hoping i could fix it but it just broke off again. Anyone know where i could get this?
slw240sx
Car: 1990 Ca18det 240sx Hatch
what part of it?? the FICD thing? ot the AAC vavle itself?
Doogz
I'll pretty much need the whole assembly. There's the AAC valve, then behind that and above it is that long metal deal and that has snapped off. I'm not around my engine right now so i'm not sure but i think they are on 2 seperate plates and i might just be able to get the back one with that piece on it, but i don't know. If you could help me out i'd really appreciate it.
boost_boy
I got an extra one if needed!
Doogz
I most definately need it! You have the whole assembly correct? Email me so i can take it off your hands. [email protected]
mattlord42
Car: 1991 240SX Coupe
Hey Doogz--
Just wondering if you ordered your engine from Venus? I ask because we just got a CA clip in for a customer from them and the AAC valve and that other part were both broken on our clip too. I was wondering if this is a common problem they have with shipping there motors.
Matt
slw240sx
it is matt.. they just stack clip on clip with out the hoods there fore breaking alot of crap thats high up on the motor!!
Doogz
Yep, got it from Venus. You can tell that they had stuff sitting on it because the firewall was caved in a bit and the hinges for the hood were all bent over.
Doogz
i know this is old but i'm having trouble getting in touch with boost to get his AAC valve so.....Could i just go to nissan and get this same assembly on a different motor or not?
mattlord42
Hey Doogz-
I just took some pictures of our broken assembly with a digi cam and e-mailed them to venus and they have new ones on the way for us. You should give that a try... we didn't have to pay a cent which is how it should be.
Matt
slw240sx
doogz, do you just need the FCID and AAC valve themselfs?? cause i just used a AAC valve off my 90 ka motor and it works !! just swap the inside piston thing with the one from the CA they are a bit differant ! same with the FCID! but yeah any AAV should work if the actuall plate they connect to is broke, contact the supplier and get that replaced since its not on u.s cars , i dont think!
slw240sx
doogz IM me on AIM if you can i think i have a solution to the problem!!!!!! but i need to talk to chat with yah !
slw240sx
slw240sx, or sidefxs1
Doogz
Jon- I don't use AIM...for some reason i have always disliked it. I'll try going to one of my friends houses later that has it and seeing if you are on.
Matt-I like the pic idea...especially the free part. I'll give it a try and hopefully they'll help me out too.
