twotonedrift »
https://forums.nicoclub.com/twotonedrift-u163168.html
Mon Jan 24, 2011 7:52 pm
well thanx for replying. ive had a hard time just getting that.. . but thats the thing man. i 'have replaced the wire' already.. i think my issue is either one of the 2 wires on the 3pin plug to the ignition harness.. i looked at a buddies ignition harness and compared to mine. . each coil pack obviously has a ground signal and power wire,yes... but # 1 signal wire connects to ONE of those black wires on the 3pin plug also right???(i dnt have that at the moment) i have tried both wires, and it just grounds out #1 coilpack. wich is what i believe makes the car run only 5 cylanders every split second i rev or drive it and will eventually fry . .
all i know is that i have seen this motor run fine before i bought it. and when i swapped it in to my s13, all the sudden #1 wasnt sparking at all. . i cut the existing wire, and ran a temporary new wire from the ignitor strait to the pack. it fired., but ran like doo doo. .
i need someone to verify were those 2 black wires go FOR SURE.. i know one is a earth and one is apparently the ignition signal/timing loop?,and pins out to the ecu.(10, 20) . . and the other is a chasis ground.
needless to say, if im looking at this raw harness what do i do? or more specificly, were do the 2 black wires go.??? i swear im not super dumb, but guys, im serious when i say ive tryed everything. . im starting to think im over looking the problem. . can some verify for me plez. im about to go pull my entire harness out. thanx again!
