SUITE E »
https://forums.nicoclub.com/suite-e-u16742.html
Mon Dec 06, 2004 2:54 pm
It is on the back of the trunk face. Remove the liftover trim, the long plastic part running the width of the trunk between the tail lights. Gently move the carpetted panel away from the sheet metal and as you stand over the trunk, just to the left of the trunk release mech is a small black or green box measuring 1' X 1.5" X 3 or 4" with a small plug attached. Did not know there was one. Thought all brake lights just run through the switch to maybe a relay. My partner has the green one and it has a brown burn mark on the side. When we put mine in his car he had working brake lights. So therefore I believe the 'sensor' is bad and need a new one or even used if the price is right.
