Ba11erz »
https://forums.nicoclub.com/ba11erz-u123579.html
Fri May 28, 2010 6:18 pm
To the best of my knowledge, they are compatible but I do have a few questions:
Q1. Do you know why your current ECU malfunctioned? (perhaps there may be a wiring fault or bad connection somewhere and you would end up with the same problem with another ECU)
Q2. Was your ECU socketed? If so, may I suggest you ensure the new ECU is also socketed and you write the saved *.bin file from your malfunctioning ECU to a new chip.
There will be other comments to follow, so read the feedback from others and the experts before proceeding.
Good Luck
