s0m3th1ngAZ »
https://forums.nicoclub.com/s0m3th1ngaz-u27191.html
Mon Jun 07, 2010 10:01 pm
I usually pan-sear them.
Defrost them to room temperature. Little salt pepper on both sides.
Pour some oil into a cast iron or SS frying pan. Enough to cover the bottom. Just make sure it's non-stick.(If you want a pan sauce)
Heat the oil until it just starts to smoke.
Then toss er in. Careful...and I don't recommend doing this over an open flame...it'll most likely splash hot oil all over the place. Use a pot lid or those wire screens to contain the spatter. A couple minutes on each side depending on thickness should be enough.
Then...if you really want to get fancy...you can make an awesome pan sauce with some red wine or sherry, cream, garlic, salt and pepper. All that black s*** left over will deglaze when you pour the wine over it.
I've never actually grilled pork chops though...
