Need A Picture
Dire91
Car: 1997 Nissan 240sx SE
EDIT: Would 17x9.5 +17 be any different in fitment than 17x9 +17?I'm looking to get new rims for my car since the stock ones are ugly and very small. I like the Work Emotion XD9's and was wondering if anybody had a picture of them in matt bronze on a black kouki s14. Would the dimensions 17x9.5 with +17 offset all around be a good choice? Thanks , Dire91
Modified by Dire91 at 11:46 PM 8/31/2008
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
that might be a little large in the front. I run 17x9 +25 in the front and I'm definatly going to need to run some negative along with a stretched tire...also a spacer for the coils.
The extra .5 and +17 might be enough to force you to roll the fenders or do some more stretch. You would be about another half inch out then me...
Compared to stock you would be out an extra 55mm-65mm
I'm no wheel expert though, just some advice.
ThuG LyFe
Car: 95 S14
^s13crazy
i think for s14's it's a little wider. i have 235/40 on 17x9 +20 and it fits perfect.
i wouldn't be surprised if 17x9.5+17 fit all around...i can't remember his name but a guy here has it on his white zenki. it looks pretty good but i would rather get cr kais.
Dire91
sr20power is the guy you're thinking of i just can't find any pics of his car adn those are dimensions he has as well.
n240sxfnatic
those are perfect sizes for an s13 all around
Dire91
would a 17x9 +17 be any different in fitment then a 17x9.5 +17?
n240sxfnatic
yes the 9.5 would be 6 mm closer to coilovers or struts and stick out 6mm farther as well
Kckouki
Car: '97 Nissan 240SX
Dire91 wrote:would a 17x9 +17 be any different in fitment then a 17x9.5 +17?
ughyea
17x 9.5 + 17 would be like17x 9 + 12
AZ89two4Tsx
^ Not really Casey
In 17x9.5x17
17-inches9.5-inches17-mm
smocan
17x9.5 +17 would be fine for you to run. Just a tad of stretch on the tire for front clearance. I know your using an s14, but i had 9.5 +20 on the front my s13 with 1mm clearance from my coils. Although all coils arent the same, if you need any extra room, you should only need 2-3mm spacer max.
___The REAL MATH. You can't compare different widths and explain with offsets.
If starting with a 17x9 +17....
A 17x9.5 +17 would give you 6mm less backspace clearance and 6mm closer to the fender.
Spiffy240
Car: 1992 White 240sx Fastback SE
i saw the wheels and really liked them so looked them up and on the Work Website there is a list of different wheel offsets and sizes http://workwheelsusa.com/produ...el=79
right under the picture there is a list of different sizes and offsetsyou could run 17x8.5 +25 in the front and then run the 17x9.5 +17 in the rear
i love it when the wheels in the back are wider and have less of an offset, looks more agressive and give the car a better stance IMO
BEST OF ALL, all the sized come in a 4 bolt pattern, for those die hard 4 lug guys
adrianfromthecastle
Car: 1992 Nissan 240sx
**moved to the correct forum**
Spiffy240
found one on a 240sx that has the staggered idea i was talking about
im really liking these wheels as well, nice choice
newdude1
do those come in a 4x114.3?
Dire91
newdude1 wrote:do those come in a 4x114.3?
Yes they do
newdude1
What size/offset do you have to get to get that sick looking staggered set up like that 240 has>?
adrianfromthecastle
ugh... theres really no reason to go staggar. If you have the choice, just go 17x9.5 all around.
17x9.5 all around
newdude1
K. What offset is that right there? These wheels look sick!
adrianfromthecastle
newdude1 wrote:K. What offset is that right there? These wheels look sick!
I think the specs were 17x9.5+17 with a 5mm spacer up front to clear suspension... tires I think were 235/40.
DIKBUTTON
TRY TO GET SOMETHING WITH NO SPACERS ... SPACERS GAVE MY S13 a SHAKE IN THE STEARING WHEEL
Dire91
my steering wheel shakes when everything is stock, could it be the stupid 3inch ebay catback?
WizardBlack
Car: 1977 Datsun 280Z w/ RB25DET
DIKBUTTON wrote:TRY TO GET SOMETHING WITH NO SPACERS ... SPACERS GAVE MY S13 a SHAKE IN THE STEARING WHEEL
Your spacers aren't centered on the hub, then. Take the wheels off and re-center them.
WizardBlack
Dire91 wrote:my steering wheel shakes when everything is stock, could it be the stupid 3inch ebay catback?
Maybe you just need some ball joints replaced or your wheels need re-balanced. They don't stay balanced forever and wheel weights can fall off making it worse.
