Need a pic of a nismo fpr on rb25
Jimefam
Just got my nismo fpr today and I want to see one installed so as to do it right. It might be very simple I just dont have the intake manifold at my house right now but this thing looks like it wont bolt on. Noob question I know but help me out. I searched.
Jimefam
Heres the one I got. I think its the wrong one though.
BoostFab
Car: S13cp, S13fb, S14z
just look at the old one and swap it. how hard can it be?! make sure you open the fuel cap, so it release the pressure, before taking off hte lines.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
you are correct. That is the wrong one. It looks exactly like the old one. Just has an adjustment screw in the back.
Jimefam
Thanks. Dammit I knew that didn't look right. Thats what I get for ordering over the phone.
USMCgetsome
supposed to look like this one!
http://cgi.ebay.com/NISMO-FUEL...0.m14
although, if your using a non sock fuel rail that could work in your favor!
Jimefam
AHHH yeah that looks like it fits perfect. Thanks I will send this to Nismoparts.com
Joe
BoostFab wrote:just look at the old one and swap it. how hard can it be?! make sure you open the fuel cap, so it release the pressure, before taking off hte lines.
that will not release the pressure in the lines.
StricNyne
i got the same one and it works for me, u just need an rail adapter.
gawdzilla
Car: none
get the one that goes into the rail directly. much cleaner.
StricNyne
u aint lieing it took me forever to find a decent mounting point and it was my friend "350g" who figured a decent spot i think aeromotive also makes a bolt on solution too and synapse does as well
gawdzilla
Car: none
StricNyne wrote:u aint lieing it took me forever to find a decent mounting point and it was my friend "350g" who figured a decent spot i think aeromotive also makes a bolt on solution too and synapse does as well
thats because aeromotive and other aftermarket universal FPRs are meant to be remote mounted. nismo is oem replacement, so most ppl mount it how you're supposed to.
*cringe* at your remote oil filter barb setup
imotion s14
Car: 1997 240SX
Jimefam wrote:Heres the one I got. I think its the wrong one though.
That's the Nismo/Tomei Type-B for universal mounting applications. The Type-A is the direct replacement and bolts to the fuel rail.
StricNyne
lol remote is until i can afford to build my oil cooler and remote filter setup with thermostatic and here is synapse that bolts onto the rail http://www.synapseengineering.com/
