Need a part number or application for 5 bolt axle
RobDET
Car: Cars
I need the bolts that attach the 5 bolt axle to the VLSD rear end. I bought my differential from Marco Vargas. It's suposed to be a 180sx rear end but it could be any of the 5 bolt ones. I need a US application or a part number so i can get the bolts. The 6 bolt axles have slightly smaller bolts...
Thanks
driftaholic
Car: '91 Nissan RM S13
you can use any bolts that fit. i have 5-bolt axles and just got some bolts and nuts from a hardware store. been runnin it for about 6 months with no problems.
RobDET
Car: Cars
I want the nissan ones becuase they aren't threaded the whole way. The base of the nut is tight in the hole in the axle and differential. I want them like that because if their is any play at all it's likely that a track launch on slicks will shear them off.
s13sr20chris
hicas s13 has five bolt axles.
