wagner »
https://forums.nicoclub.com/wagner-u132295.html
Sat May 30, 2009 3:01 pm
Hello,
let me start off by saying that in the world of Nissan I am a dumbass. Now that that's out of the way lets get started!
So, I replaced my thermostat and have had s***loads of trouble since. First off, since embarking on this journey, I have managed to break every bolt into the t-stat housing but have been lucky enough to get them out ( three separate times, broke a bolt each time ) i'm not sure why these bolts are so brittle, I dont apply much pressure. Secondly, I've tried applying my own gasket, and a gasket off of a sentra and every time I put coolant in it just starts pouring out of the thermostat housing. Lastly, the last time I thought I had it, I was tightening all of the bolts down when the water outlet that connects to the thermostat housing cracked, and subsequently, broke off completely. So, I need to find another one but I dont know where to get one, or who makes a replacement.
If you guys could Help I would appreciate it so much. for the thermostat housing bolts I've been using M6 1.0 16mm's to replace the factory bolts that broke, I'm not sure if those are good enough of not but iI would appreciate the appropriate bolt length/dimensions if you guys could.
EDIT-------- this is on a 1991 Nissan 240sx with a red top SR20DET
Modified by wagner at 6:06 PM 5/30/2009
