need a new transmission, what are my options???
madBOOSTED
Car: 98 Nissan 240sx
so i need to get a new transmission for my s13 Blacktop, what are my options?is there a better transmission i could get from another nissan or something,any info is aprecaited thanks
garagelu
Car: 1995 240sx w/ sr
Either get a s13 or s14 replacement trans or find a ka24 trans and swap the bell housings. Or....you can spend 5-6000 dollars on a HKS or OS Giken trans.
240_SeX
Car: 1992 240SX SE
Search around, Mazworx makes a trans adapter kit to use a Z32 trans, those are proven to withstand tons of horsepower. Before you make any purchases you need to consider what your going to do with the car. Do you really need a stronger trans? How much are you looking to spend? trans kits can be expensive.
Narciso
Car: 180SX
S14 is the strongest out of all the Silvia's. A lot of people here in Japan turn to that or they get a VQ transmission but you have to get an adapter for it.
nzmoman
Car: 240sx 2 of em' and always lookin for more
240_SeX wrote:Search around, Mazworx makes a trans adapter kit to use a Z32 trans, those are proven to withstand tons of horsepower. Before you make any purchases you need to consider what your going to do with the car. Do you really need a stronger trans? How much are you looking to spend? trans kits can be expensive.
what he said.^^^
decide what the car is for. Almost anything you are going to do with the car can be done reliably with the factory transmission. If you are wanting to play with gearing a bit then you have the KA/SR/Z32/I think they even have a way to use the Z33 6pd...or you can go baller and go Giken, Dogmission (only for the serious build) or HKS.
240_SeX
Car: 1992 240SX SE
Narciso wrote:S14 is the strongest out of all the Silvia's. A lot of people here in Japan turn to that or they get a VQ transmission but you have to get an adapter for it.
All SR transmissions (except S15 6 speed) are the same
Kalypso
a z33 trans is baller.
but all of this is fantasy without knowledge of your driving style and budget.
SpeedRacer1
Car: 1990 240SX, G35
If you need an S13 Kouki/S14 SR transmission I have one for sale in Alexandria. Let me know if your still looking. 425 246 0421 Nick
MastaYu
Car: 92 Nissan 240SX SE HB
Kalypso123 wrote:a z33 trans is baller.
