I'm having that issue right now. Sometimes it starts fine with no problems. Other times it just acts ghey. It usually starts on the 4th try when it's acting up. I'll tend to it this weekend.jamesblonde82 wrote:hopefully its just your starter, because after i replaced mine it still would just *click click click* sometimes before it started...so i replaced the battery cables and it works now. also there is a relay somewhere you can replace...but sounds like its your starter if you gave it a good wack and it came to life.
i have the part numbers for the new cables. you have to get them from nissan because they have all the harnesses on the pos cable, but you can get the black one from courtesyparts.comBOOMSHAKALAKA wrote:
I also have to deal with my stereo, clock, left rear side marker, top light, map lights, and some of the dash lighting. They all gave up on me a few days ago.
A mechanic who knows 240s very well quoted me $50 for the labor. I think your mechanic will drop transmission mount and tilt the engine and that's why labor is expensive. Find someone who's swapped starters before on 240s using rachet wrench just like jamesblonde82 did.ebalita wrote:he said $200 with labor.
