Need a new crankshaft asap
DawgMode
Car: 180sx
where can i get one????
I messed up my crankshaft bearings and i think i scratched my crank...how much will a new one cost
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Just out of curiosity, how did this happen? Oil starvation?
robbbby
TODA stroker kit time
Check around I saw one for sale in the classifieds either here or FA.
DawgMode
Car: 180sx
bad oil and heavy driving
Onizuka
As long as your taking things apart, inspect camshafts and the crank girddle on the block for scoring. You whole engine may be scrap, or everything could be perfectly fine.
If it happens to be just the crank thats messed up you can get a crank and a set of used bearings (i recommend new bearings) from any store that parts out SR's. http://www.sr20store.com is one that comes to mind.
SpeedRacer1
Car: 1990 240SX, G35
Well the part number for the crankshaft is 12200-60J10 if you can find a dealer that will order that part. You use the markings on the crackshaft to determine the bearing thickness.
DawgMode
Car: 180sx
When my engine started the knocking i immediately turned it off so im praying that there isnt any scoring
