Keep in mind that my career was that of operation of electrical generation equipment up to and including 750 MWG hydrogen cooled generators, gas turbine driven generators, diesel, and hydro prime movers. and training others in their use.audtatious wrote:
Having a secondary battery can make things worse if not done properly.
The voltage regulator keeps an eye on the battery by turning current to the field (stator) terminal of the alternator on and off. By design it should not be a constant charge to the battery.
Simply adding a second battery can make things worse unless you use a "smart" configuration which will monitor the main battery charge before allowing the secondary battery to be charged while runing (different than using battery isolators). In general, adding a secondary battery is good for allowing the owner to listen to the stereo without the car running while ensuring the main battery is not drained. While driving, the proper solution is to use the properly sized alternator.
I run a similar scenario with my other car which has a 5 channel 100 watt rms per channel amp. It will drain the system down quickly with the car off. With the car running I never have an issue, but I do believe I am at or close to the limit. In the 'G' I would consider the second battery in the trunk with possible provisions to monitor it using the 'G' monitor system for charging purposes with the addition of a couple of components. From my observations I believe I would be ok, but again close to the limit of the rated power output of the alternator (although there may be a 30% fat). This assumes stock lighting, etc.audtatious wrote:
Now, going through the '08 coupe FSM I see what you mean. The battery current sensor monitors the battery ground cable and communicates the information to the ECM which determines if the battery needs charging and sends a calculated value to the IPDM E/R which then communicates to the regulator for the specific amount of power. It also looks like the system defines 12-13.6v as the default when alternator duty is 40% and will increase the voltage +.5v or more when the duty cycle hits 80% (settings viewed via Consult)......This is the normal operating flow and set variables for the system.
Now, in the case of my coupe, in which the alternator has a nominal rating of 12v and 150a, what happens when you are running the car with accessories/audio system on and you reach peak amps? Say you are running headlights, fog lights, A/C and you are in mixed-city driving, my assumption would be that you are OK as the alternator should easily be able to provide power to run all accessories in that situation (although I have not found anything showing what the maximum amperage is with all accessories running). Now, what if you added a high-end audio system on top of that which could pull 80-100a (Don't laugh, I've blown the 50a fuse numerous times with my PPI A600 "back in the day" and it was only 1 of 3 amps I had in the car)? My assumption would be, regardless of the electronics involved with the Infiniti charging system, that you would be in a scenario where you are pulling power from the battery which leads us right back to a battery drain issue. I didn't necessarily see anything within the charging system diagram which would limit such events from happening (which you also stated above).
I would agree if the battery was simply an addition to the main and not installed in a smart way as far as charging. And yes the alternator does have to be sized to match the load regardless of its presence. In the case of the second battery the idea is not to add its charging load in at the same time as the main although in reality it probably will not need to exceed about 10-15 amps if fully drained. While charging you could still use the audio system.audtatious wrote:While I have nothing against 5 channel 100w amps (I loved my a/d/s PH15), try a 400w amp running a 1ohm load and pushing 800w+ to go along with your 100w amp
Unless you are using the system for listening to music when the car is off then I would avoid a second battery altogether and look at ensuring you have a properly sized alternator. When driving around and jammin it would be eaten up relatively quickly and the alternator will still need to try and charge it which would strain the system and be annoying as hell when you can't properly hit those bass transients. The only positive is that with it properly isolated you would ensure the main battery itself is not drained.
In the old days I did have something really unique and that was a battery I center tapped. The reason was that my car was a 6 volt positive ground and I wanted a then state of the art 12 volt transistor radio. The battery sat in the trunk for another reason and that was the 12 volt dynomotor for my a/c black lights. Starting the dynomotor was a trip. Basically turn all loads off and spin it up to speed, then reenable everything. A group of knife switches did the trick. My friend had one in his 12 volt Plymouth. He faired better but it was wise to turn off the headlights first. Great fun, no one else had anything like it and the dyno sounded like a small jet spooling up.audtatious wrote:In your case a second battery would be fine as you are not really taxing the electrical system that much with your one amp while driving. The problem that some have is that they add multiple amps which have huge power consumption requirements that simply can't be sustained by the alternator. Adding a 2nd battery as a solution in that situation is not appropriate as they are simply adding another reservoir that the already over-burdened alternator has to charge. Even with adding an isolator and running the system off the second battery they only have so much storage in the second battery to utilize before it's drained and they are further limited by the isolator, thus the amps don't get the power they need, it sounds like crap and you can get clipping and such which can destroy the components.
Price also comes into the equation. Adding a good 2nd battery can cost $100 (or 200+ for an optima). 1ga power wire can run another 50-80 bucks for the good stuff. Aother 20-30 in terminals brings the basic cost to over $200 and that does not include the battery mounting kit nor the isolator, etc. The end result could be upwards of $300-400 to do it right which does not make sense when you can get a 190amp alternator for just over $300 (I saw $325 with exchange online)
One issue with the 190 amp alternator is that there are some possible limitations due to the stock wire size. Replacement of the fusible link and possibly associated wiring also needs to be taken into consideration but that is a fairly easy task. The alternator needs to be done if the stock one is overloaded but the rest of the system may need a little refreshing as well so the cost could actually increase over the number stated.audtatious wrote:
Sounds interesting for sure. I never had to deal with 6v systemspfarmer wrote:
Perry
For the newer G-style systems that might be a possibility ( ? ) and would need to be looked into to see if that would indeed be an issue or not. I'm sure if there was a limitation it would be the wire size between the alternator and the IPDM to battery and possibly ground which would need to be upgraded, assuming you are still trying to pull power from the factory wiring. Otherwize there won't be an issue from a voltage perspective as the HO alt is still staying within the 13-14.4v range. You can also upgrade to a dual output alternator (which most also include battery isolators) in which the audio system is connected directly to the alternator itself, with dedicated battery if necessary, and bypass the factory battery system charging lines.pfarmer wrote:One issue with the 190 amp alternator is that there are some possible limitations due to the stock wire size. Replacement of the fusible link and possibly associated wiring also needs to be taken into consideration but that is a fairly easy task. The alternator needs to be done if the stock one is overloaded but the rest of the system may need a little refreshing as well so the cost could actually increase over the number stated.
Perry
While still in HS prior to getting our drivers licenses I assisted a friend cram a 58 Pontiac engine (12v) into a 51 Ford (6v). Your bringing up knife switches brought back memories. We double dated and took turns in the back seat and......... Ahh the good ole dayspfarmer wrote:
Perry
A lot of Pontiacs went into a lot of Plymouths as well. Not sure of the exact why since many others were stuffing Chryslers into GM and Ford products.telcoman wrote:
While SF is usually colder than it is down here in socal, it still has fairly mild temperatures. I'd recommend a good deep cycle battery. While deep cycle batteries have slightly lower cold cranking amps relative to a typical starter battery of the same size, its likely going to be more than enough unless you see some seriously cold temperatures. The advantage is they don't go bad if you accidentally drain it. As they are designed for use in RV's and boats, they do not lose their reserve capacity each time it gets drained. I've never had to replace a deep cycle battery I bought so far. Though, in my case, every battery I've replaced was usually because of lost reserve capacity after several accidental discharges. May not be a big deal for many (perhaps especially with the G as my understanding is it can cut power to non-essential equipment when it detects the battery is running low), but personally, I'd rather be safe than sorry.Nazc0 wrote:anything i should watch out for when buying?never bought a battery so i dont know what to look for.
