Need A MAF PLUG!!!!!!!!!!!!!!
WDRacing
I'm willing to beg/borrow/steal anything that will get me a 300ZX turbo MAF plug. I'm getting the MAF from NismoFreak, but he doesn't have a plug for me. If anyone can source me a plug, I'll be able to repay in monetary or whatever form requested. Need a alcohol/water injection kit, I'll build you one. Want to run a turbo without tapping the pan, I'll build you a kit for that to.
Thanks fella's...Love You
Structure240sx
i might have a friend selling his still, he would need your stock maf plug since the one i sent him got lost in the mail. i would need a quality alky kit, too
WDRacing
I'll put one together, but your buying the parts 8)
Find out for me though.
Structure240sx
sorry mang, looks like he is keepng it to boost his ka agian. gues sthis will be the 4th engine he will try it on
crzycav86
Car: 93 Nissan 240SX KAT
Is this for an s13 or s14?
Bernard
The plug for the z32 maf is the same as the plug for the z31 maf, which is the same as the 85-88 maxima. You should be able to find one of those easily enough. DO you need to know the wiring as well????
Bernard
WDRacing
You rock Bernard. I'm now indebted to you. You could post up the wiring of the plug and save me the Search.
I'll be hitting the junkYard today then.
Bernard
Link to wiring: http://jimwolftechnology.com/wolfpdf/MAF Z32 CONVERT TO OTHER NISSANS.PDF
Are you using an AFC or programming the ecu to work with the larger maf?
Red-KAT
Car: 1995 240sx-se ka24det
I know your already the super sweet mod and this is off your topic...
But if you put together a list of all the (Detailed) parts for and ALK kit, How to install it, and where to find the parts on the net... I'm sure you would get lots of IM sex. <-- I crack myself up!
WDRacing
I'm so down for some IM sex. I think I just cybered all over myself just thinking about it...lol.
I'll post up some info for all the DIY guys. But there are some really good kits available for very cheap. I'll talk to a friend of mine who sells them and have him drop in.
PapaSmurf2k3
Site Admin
what about this damn mystery oil return kit. I thought about cutom making a oil filler cap, with a fitting on it connected to the return line, but i dont know how that would screw with the valves and stuff. Tell me what your idea is before i go drilling my freggin oil pan. Theres some free clamcakes for you when you come up here if you tell me
DRIFTEADOR
can't you use a pump into a filter relocation/oil cooler kit?
edit: without having to switch to dry sump*
WDRacing
I'll make a new thread....
