Need a little more bass... suggestions?
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Tim30250
Car: 2009 G37 Journey Premium/Nav/Cargo Net!!! 2002 330Ci - Supercharged
The performance of my Bose system is okay enough for me, but I need a little more bass. It's quite adequate when listening to hip hop, but I listen to a lot more rock and want to feel the bass drum without having to blast the volume.
I'm not doing a bass tube since I've never had success with those in a trunk. Is there a factory location sub replacement w/ aftermarket amp solution or should I do a box in the trunk? Also, if you suggest box, would you recommend a single sub, or duals? And, of course, let me know what brands you like.
Thanks in advance for your input.
audtatious
I'd suggest a small fiberglass enclosure in the trunk. Upgrading the door 10's would be nice but I don't believe anyone makes one slim enough to fit properly.
Tim30250
I thought I was likely going to end up with a trunk subwoofer. What are most guys using in their G35/37s? One 12", two 10s??
audtatious
I'm sure either would work dependent on location.
joe603
Car: 2014 Durango R/T
In my 05 G35 coupe, I had 2 10's pushed by a large amp...plenty of bass. With the new G37, I'll probably do the same. For the amp high-level input, I'll use the rear deck "sub" and solder on RCA leads.
The subs will probably be mounted on the sides again...(here's a pic from my G35)
Just need to secure funding
audtatious
and save for the kids college fund
Tim30250
Joe, I love the idea of the side mounted subs. Doesn't seem to consume much room and it looks fantastic. I'm going to check into the cost; it appears to be a custom job and since I'm no good at fabrication I'll have to retain the services of a trained audio design professional.
joe603
Yes, it was custom. I had a friend who is a master installer at an audio shop do it in my driveway and at his home. The process isn't too complicated, but unless you're familiar with fiberglass I'd let a shop do it.
J. Dizzle
Car: 2004 Infiniti G35x
That's a nice, clean install. I think you just inspired a s***load of G drivers.
SavG35
Car: 2004 Infiniti G35 Coupe
So what would you say the a good price from a local audio shop would be for doing a one 12 in the side trunk wall?
joe603
I still have my old box if anyone's interested...I mounted the amp in the front so when you put the seat down, you could adjust it.
It's sitting in my spare bedroom along with the finisher cover, collecting dust...make me an offer!
Return to “G35 and G37 Interior, Exterior and Audio”
