kouki_monstor »
https://forums.nicoclub.com/kouki-monstor-u33270.html
Sun Dec 24, 2006 12:00 am
my car has been idling really high ever since i swapped in the new motor, it runs great, except for the fact that it idles aat about 1500k cold and then goes down to about 1100k after warmed up. that's still really high of an idle, plus the fact that it backfires alot and sometimes it would make such a loud pop that it seems would be damaging to the engine. i've decided to try and fix it, and after researching ive narrowed it down to bad timing and possibly the tps. now the tps has never been removed, but i decided to test it anyways.
it's weird, because according to the instructions, it would be about 2.0 ohms released and 10 ohms when depressed. now, by released im assuming that means when the throttle is fully closed, and fully depressed means when it is at WOT (wide open throttle). if im correct, then my tps is giving a backwards for some reason. im getting about 2.8 when the throttle is closed and about 8.5 when it's open, which is comepletely backwards. i dont think adjusting the tps would fix this problem. would anyone know whats wrong with this picture?
also, when i check the voltage of the tps, which, according to the FSM, should be .4 volts closed and 4.0 open? well, mine gives off about 4.5 volts when closed and goes down to about 1.2 when i open it. again, completely backwards. im i doing something wrong? im measuring ohms and the 20k ohms setting and voltage at the 100 setting, and im pretty sure the negative and positive terminals are correct. besides, would a wrong neg and pos terminal cause that?
hopefully someone could have an answer to this. ive ben pulling my hair out for the past couple of days trying to figure this out. and trust me, ive searched. any help would be great. thanks!
