adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.html
Mon Dec 17, 2007 10:47 pm
1) sure. Pretty much all popular coilovers have the same clearance, with maybe a difference of 5mm
2) put your wheels on first, then find out if you need a pull or not. It really depends on your camber and if you want a tire stretch... but with the tire size you provided, you may need a slight pull... for example
this is what a 10" with an offset of +18 (similar to that of your 9.5 +20)
as you can see, because of his stretch, a crazy pull isn't necessary. I guess that's really up to you if you consider a stretch. The pic I provided is with a 235/40/17
3) Dude... with the wheel and tire choice you provided, you won't even have to worry with a pull... you should consider a lower offset, especially since the wheel width is smaller. Just make sure you check with the manufacturer specs that the desired lower offset still allows caliper clearance...
I'd say for the fronts, go with like a +20 or less (personally, I think a +15 with a mild stretch and ever so slight camber is perfect), and depending on camber chosen, you may not have to need a front pull...
but, regarding you front fenderpull question, I don't think its possible to roll it like you'd do with the rears, cuz the whole damn fender moves and flexes with the roller! lol seriously tho, its easier to get an thinner roll if you take the fender off and do it on the grass or something... that's what I did... it allowed at least like a 10-15mm clearance... hell, I rolled my cousin's front fenders with a hammer, lol... it worked out well too
