Qlicious »
https://forums.nicoclub.com/qlicious-u22227.html
Mon Jan 24, 2005 1:39 pm
Does anyone know if I have a bad egr temp sensor, will it always give a code?
I've been getting a code 32(egr). I've cleaned everything, changed the egr solenoid, and checked for any vacuum leaks as well as I could without actually taking the plenum off. I've even swapped out the actual egr valve. I'm thinking that either my temp sensor is bad or that my bpt valve is bad. I've checked the sensor according to the FSM, short of putting it in hot water and checking the resistance. I got 3.5v from the harness(FSM says approx. 5v) and continuity does exist. When I checked thevoltage and continuity on the sensor with the car running, I got nothing.
Someone please help, because I've had the car 2 months, I love it, but I can't figure this one out.
