nissanfanatic »
https://forums.nicoclub.com/nissanfanatic-u21678.html
Sun Oct 16, 2005 12:42 pm
The stock oil pressure sending unit is BSPT. You'll need another adapter like you recieved to adapt the T to the block.
For the injectors, use a flat-edge screwdriver to pry the injectors out.
After you remove the cap, put the two screws back in the holes and screw them all the way in. Then use the screw as a leverage point with the flat-edge. Using both of them with two flat-edge screwdrivers is the way to go. More of an even lift. Contine to twist the injector between prying.
Sometimes you have to do a lot of bleeding to get the clutch to work right. I bled the hell out of mine. Also, speedbleeders kick ***. If you don't use speedbleeder, fill a container with fresh fluid and run a hose from the bleeder nipple to the container full of fresh fluid. That will keep air from entering the system while bleeding. Makes bleeding a lil easier too.
