actually, you have to cut and extend 2 plugs, and then re-wire 3 more, but thankyou.CSUPUEBLOTIM wrote:You just have to cut and extend 3 plugs, you can remove the unused ones and swap out the dashboard connection. The write up is pretty straight forward. Your issues before could have been numerous things. Just take your time and be sure you solder and wrap everything. Don't use butt connectors. Good Luck.
