LiU »
https://forums.nicoclub.com/liu-u490.html
Sun Feb 08, 2004 10:02 am
doing the rear AGX and RSR springs. Here are my problems:
1. on 1 side the 17mm bolt bolt that holds the shock to the suspension won't come loose. Soaked it in pb blaster all night to no avail. I think I'm going to try to jack the suspension arm up along w/ the shock to see if that'll help making it easier to loosen the bolt.
2. the other side was easily done, the new shock and springs is sitting on the car. However the torque spec according to the FSM is 72 lb ft for the 17mm bolt, which is like 840+ lb in of torque. I've tried as hard as I can to torque the bolt, but it's not there yet, I read fiznat's install and he recommended having the car on the ground before torqueing everything down. I don't have ramps, so any other way to torque them down to spec?
any thanks is greatly appreciated.
err I posted in the wrong forum, can some1 move this to the 240 forum? thanks.
