slow40 »
https://forums.nicoclub.com/slow40-u57194.html
Wed Jan 14, 2009 2:57 pm
if it's trying to turn over but not fast enough and you have a new battery, then you probably have a bad starter. If it is just not trying to do anything, then you can take a screwdriver and (making sure the car is not in gear) touch the hot post and the other post on your starter. there will be sparks and this is a little dangerous, mostly from starting a fire, or if you have a fuel leak could get really bad. had to do this method on my nissan truck for a while. if it won't turn over that way, then
