LugNut18 »
https://forums.nicoclub.com/lugnut18-u128130.html
Tue May 12, 2009 1:18 pm
You won't get a smooth ride with coilovers. Especially the lower end ones. Most Sub $1500 coilovers have crappy valving. Also, they are designed to go really low, which kills the roll center of the car, that would lead to more body roll, which is why they run stupid high spring rates. Although they would look good. If you have the money, KW variant 3's would be the way to go. Good valving, and 6/4kg spring rates, perfect for street use (stock is like 2/2kg). But the choice is up to you.
