Need a few parts for my 95 J30
smartbeatz
Car: 1994 Infiniti J30
Here is a list of the things I need so if you have ANY of them please let me know. Thanks in advance.-The wire harness from the positive side of the battery. Not the whole thing, just the side that connects to the battery itself. -power regulator for my drivers side window and back passengers side window.-power sunroof console with the 2 map lights.-drivers side amber side marker
I also have an issue with my passenger door. It only unlocks with the key in the passenger door. The power door lock switch does not work on that door. You can manually lock it from the inside but not unlock it that way. It's a pain having to use the key to unlock that door every time I let someone in so any help would be greatly appreciated.
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
smartbeatz wrote:-The wire harness from the positive side of the battery. Not the whole thing, just the side that connects to the battery itself. -power regulator for my drivers side window and back passengers side window.-power sunroof console with the 2 map lights.-drivers side amber side marker
Do you need the terminal or the red connector for the power to the fuse/relay block? Also do you need the drivers side window regulator that goes on the door and controls all the windows? I know I have the sunroof console and I will have to see if I recovered the drivers side marker or not. I should have just about all of those. I just need to check when I get home this weekend. I'll keep you posted and put pics up of the items I do have.
Actually here is a link to a thread i created a while ago that has some pics of some items I have.
http://www.automotiveforums.co...08458
smartbeatz
Actually here is a link to a thread i created a while ago that has some pics of some items I have.[QUOTE=swimshark]
I need the red connector for the power to the fuse/relay block I assume. It's the part that connects directly to the battery. Mine snapped and I have electric tape and a clamp holding it on right now and I have to be easy going over bumps or else it will shut off. It's a pain when you have to keep resetting the radio too. I also could use the drivers window mechanism. The sunroof console isn't the right color. I have black interior. Do you have the back speakers? Right now I can only afford the part for the battery until after the new year. I'm also looking for the vent piece that goes across the front dash and windshield. I'm not asking you to hold them for me but if you still have them when I get the money I'll get them off your hands. Thanks for all the help. You can email me @ [email protected]
