nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu Jun 27, 2013 6:03 pm
I believe the ABS motors are the same in the Z. Eventually it will stop when it runs out of fluid, lol. Not to make the day worse, it will eat your paint and rubber up pretty bad.
I believe you can bypass the motor, I have seen it on the web before, but it will throw the bias off front and rear pretty bad. That could be a quick fix until you can afford it, just do it right and be safe about it.
