Need a Diagram of Z32 E-brake assembly
2s4k0y09
Car: 1997 Nissan 240sx SE
Like the title says gentlemen, I currently have the front converted, and I'm in the process of painting the rear calipers. I bought hardware like the brake shoes and all the bolts and **** for the e-brake, but I believe that I need the backing plates in order for this to work. So if anyone can advise me here or post up a diagram from the FSM on the full e-brake assembly, I would greatly apperciate it.
hannibal
Car: Red Line to Glenmont
You dont need the backing the plates. The Z e-brake should be able ot bolt to the S chassis's spindle.
Go download an FSM from here. http://www.carfiche.com
2s4k0y09
The brake shoes, once engaged, have to press against something. I just can't figure out what exactly they would press against on the spindle. That's what is confusing me. It's probably a simple thing too.
crzycav86
Car: 93 Nissan 240SX KAT
yeah, you do need the backing plate. it's the piece that holds the pieces for the assembly together. it gets sandwhiched inbetween the hub and the spindle - the spindle doesn't have anything to do with the ebrake conversion.
read this http://importnut.net/300zxbrakeswap.htm
2s4k0y09
Yeah that's what I thought. I also was having a brain fart on how the e-brake shoes work, but it was right in front of my face in that it utilizes the inner part of the rotor. I also see how that backing plate works in the assembly as well. Thanks for the reply crzycav86.
