Hi
I'm Jez from Horsham Developments. I've just been speaking to cuzan0 on messenger and he asked me to post.
With regard to the original question, I don't currently do an off the shelf chip for the J30 AFM and 550cc injectors. I do do a chip that will work very well the S14 T28 however, but that requires a Z32 AFM and 440cc injectors (which I can supply if required). That'll give around 285bhp at 15psi, or with a T28 hybrid around 315bhp @ 17psi.
IMO you can't guess the mapping for a chip - you need to map it on a rolling road while monitoring fuelling optimising ignition timing - that chip will then work quite well with others car of a similar specification.
The fuel cut is there for a reason, but who wants to be limited to ~200bhp...
On a completely different note, heres a couple of pics of the engine I'm about to install into my S13
http://www.h-dev.co.uk/images/...1.jpg and
http://www.h-dev.co.uk/images/...2.jpg
