need 240sx help asap
pugnastyS13
Car: s13
ok i have a 92 240sx and my motor blew up so i bought a motor out of a 95 s14 and i put it in everything went good but there are 2 plugs that were on the s13 motor that arent on the s14 motor they are located beside the valve cover on the fire wall side they have a bunch of vacum lines going to them do i need those plugs what do i do
Chukidori
Can you take a picture? It will probably GREATLY increase your chances of success at getting a help full response.
JeromeS13
Car: 2008 Subaru Impreza STI
Are you using the S13 intake manifold? If not, you should... Then, everything should plug up.
-Jerome
