Ned help identifying this plug and why mine was unplugged??
seaweedmcgee
Car: 1998 QX4
I just noticed it being unplugged. The two actually don't match up.
It's directly under the driver's dash next to hood latch as you can see the gas pedal.
Are they both meant for the code reader's?
Thanks!
patqx4
Car: 2002 QX4
Idk about the male plug but the female is the obd2 plug-in.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Does the gray plug mate with the white one? If so trace the gray plug cable. There may be a data logger on board somewhere.
seaweedmcgee
Car: 1998 QX4
Chuck Tribolet wrote:Does the gray plug mate with the white one? If so trace the gray plug cable. There may be a data logger on board somewhere.
Nope they do not match up.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Might be harness M9 "Data link connector for GST", FSM says it's gray and has 14 pins, and is in the correct area.
snewkirk2
Car: 1997 Pathfinder SE
The metal clip just above the grey harness in picture 1 is the holder for it. The harness will be facing down like the white harness is.
Towncivilian
So it indeed is the other data link connector?
Chuck Tribolet
'87 Chevy Corvette
GST is FSM-speak for "OBD-2 code reader". The WHITE connector is for the OBD-2 code reader.
Towncivilian
You're right, I am mistaken. I meant to say that it was M11: Data link connector for CONSULT, as that one is gray and has 14 pins; M9 is white, has 16 pins (ODB2).
Chuck Tribolet
'87 Chevy Corvette
What TownCivlian said. The grey connector is for CONSULT, which was the first generation Nissan hand-held
mechanic-in software. They are up to CONSULT-III now.
For the geeks in the crowd, think of them as tablet computers with special software for fixing your Nissan. Their capabilities
go far beyond any retail OBD-II scanners.
Chuck Tribolet
'87 Chevy Corvette
And to summarize: put the gray plug back on its clip, and don't worry about it.
seaweedmcgee
Car: 1998 QX4
Thanks everyone!
