I prefer having a minimal equal length gap around the entire wheel well. I don't like overlap on top with gaps on the sides.240hatchsx wrote:All though SX APPEAL is correct I look at it this way
Wheel gap is like vagina the more fingers you get in there the worse it is ...
That's what I'm going for. I want to stuff bigger wheels in there. 17s or 18s, with decently sized tires (not a fan of the stretched look).alms24sebring wrote:Well you can fit more in there.
Anyways, altho its probly true that its mostly looks, you do definantly gain some better stability at the cost of tire durability. But if you spend a good amount on it, It pays off IMO especially if your buying it for function and a purpose.
Can you elaborate on this?danshaz82 wrote:and, there are parts companies that do make knuckles and other parts to correct rods pointing upward. so you can go pretty low while still maintaining a factory geometry set up
The car will want to roll more, but if it can't roll because of the springs, it will still be more stable, with a lower center of gravity.Razi wrote:Once your lower control arms go past the point of being parallel to the road and start pointing up, your roll center will be below the car, and the car will try to roll more. (But you won't notice since you're on stiffer springs.)
And the way your wheels gain or lose camber and toe will be different and messes with your traction.
Your car won't be undriveable, but it won't be performing it's best. There's a reason why pro drifters started raising their cars.
Also, you won't be losing tire durability like ALMS said. That'll only happen if your toe alignment is off and you don't correct it.
PairMercury_Hg wrote:PSM knuckles say they're $400 to modify your own. Do you know if it's $400 per knuckle or $400 for the front pair?
You should call up every race team in the world and tell them this new ground breaking theory on suspension.mechanicalmoron wrote:The car will want to roll more, but if it can't roll because of the springs, it will still be more stable, with a lower center of gravity.Razi wrote:Once your lower control arms go past the point of being parallel to the road and start pointing up, your roll center will be below the car, and the car will try to roll more. (But you won't notice since you're on stiffer springs.)
Also, the suspension travel and how it effects alignment/contact patch should be pretty negligible, with stiffer springs. I don't think mine are stiff at all for aftermarket stuff, and with factory sway bars and a drop to where the wheels are just centered nicely instead of monster-truck-lookin', my car doesn't really lean at all compared to stock, the sprung weight seems to be all but stuck to unsprung stuff.
I'm not saying a huge drop will make the car perform much better, past a point. And I realize a 240 is not going to be prone to rolling over in the first place. But if the car's lower, it would still be harder to actually flip it or to lose traction or contact on one side. Probably more important to circut racing, so, probably pretty unimportant for most 240 owners.
240s are highly prone to rolling. My car on a set of KYB AGX's and Tein S-Tech springs had a horrible time with roll control at an autocross. I was getting better lap times out of another 240 I raced with stiffer linear springs and roll bars.mechanicalmoron wrote:I'm not saying a huge drop will make the car perform much better, past a point. And I realize a 240 is not going to be prone to rolling over in the first place. But if the car's lower, it would still be harder to actually flip it or to lose traction or contact on one side. Probably more important to circut racing, so, probably pretty unimportant for most 240 owners.
mechanicalmoron wrote:It's just a fact of physics.... lower car means it won't flip over as easily. I don't mean roll as in handle, that's obviously going to be compromised. And yes, it is going to slide more easily if perfect factory suspension geometry is not preserved. And no, I'm not saying it will be preserved, unless you happen to be nismo personified.
Just saying, it's common sense that if you put weight lower to the ground, it will take a lot more force to actually flip it over. Go try some fast turns in a big truck.
Again: I'm talking flipping and firey death, not the type of roll that a sway bar fixes. Wether or not you keep traction, actually flipping a lower car will be much harder.
