necessary for ca install?
Sinful_Ca18Det
Car: 1989 FastBack Nissan 240sx
i know im probably gonna get told to search for this and i already did and found nothing so maybe someone can help me out.
im in the process of purchasing a ca but listed is ecu, harness, transmission and motor, what other parts are needed to have the car running? does the mass air flow come on the throttle already? ignitor chip? if it doesnt how much is it to purchase it otherwise...thanks guys
pulsar gtr
Car: NISSAN VEHICLES
Double check to make sure these parts come with it, if not you definitely need them to get the car running.
Ignitor, injectors resistor pack, maf or you can use a ka24E maf but needs to be rewired, ecu, harness, intercooler and piping, and no the maf doesn't plug directly on the throttle body, it plugs at teh same location as your current Ka one is.lots of the Ca that you find usually come with the harness, but not the maf, ignitor or resistor pack.
you can search ebay, you get the maf and the ignitor, But the resistor pack, you can hit the junkyards and get one of a 1987 pulsar with ca16de engine.
Intercooler, I recommend that you go fmic.
Good luck,
PULSAR GTR
Rafi
