okevolution wrote:I would do this as it would reduce backpressure and increase spoolup. I would buy an aftermarket o2 housing that separates the flow from the WG and exhaust and have a pipe welded in on the WG side and run a Tial 38mm WG. Just weld the internal flapper shut. Trust me, it will be extremely loud
looks like in order to use that, you'd need to leave the flapper open. otherwise the wastegate would be downstream of the turbo and wouldn't really do anything. or maybe i'm looking at it the wrong way, but i don't think so.
interesting . . . i would be VERY interested to see how spool is affected. this would significantly (although not vastly) increase the effective volume between the cylinders and the turbine housing, which would definitely decrease transient response, but i want to see if the gain in response by having the external gate cancels it out for a positive gain. it's especially questionable since the flow to the external WG would still have to flow through the turbine housing and the stock WG flapper/hole.
i think i will still stick with my idea for stock manifold w/ ext. WG all extrude honed for my final solution to the spool problem on my car. and maybe replace the flange with a T3 flange. low volume, ext WG, and surprisingly good flow w/ the extrude honing (and some grinding beforehand).
